1 - 2 of 2 Posts
Just got my new CBR and the low beam lamp doesn't work. The high-beam and the center light works and the fuse looks fine. I want to check the bulb but I'm having difficulty. Can anyone tell me how to change the bulb on an 09 CBR? Am I suppose to take the plastic that's behind the bulb assembly out? It looks like it can be popped out but I dont know in which direction and I'm fraid of breaking it. Thanks.
Rotate approx. 1/4 turn counterclock wise and cover will pop off....there is a rubber gasket/seal on it, be careful not to lose it....pull off the factory bulb plug and then there's a metal clip holding in the H7 bulb. Take care when taking out the bulb not to break it and do not touch it with ur bare hands as the oils from your fingers will blow it, if it's not already blown that is.
1 - 2 of 2 Posts
