1 - 20 of 20 Posts
Just wanted to remind everyone to check their tire pressure often. I rode yesterday to work and i just was not taking turns well. It's like my bike did not want to turn. I was on a ramp from one highway to another, and i took the turn wide and went on the shoulder. Had to slow down a lot more to turn.
Checked my tire pressure and I was 10 psi low on each tire.
So check those tires !! :cruising:
Scooty-Puff Jr. Racer
Repost IMO.
Glad you're not dead though.
so what? its never a bad idea to have a reminder now and again... some people arent very attentive and overlook small things like that.. I cant tell you how many cars i see with low tires...
Glad you were able to recognize it and adjust before something went wrong!
What is my tire pressure supposed to be at while we are on it? I have Pirelli on the front and a Diablo on the back. The Pirelli said 42 psi on the tire. Seems high? Idk.
Can these be installed without any tire removal tools? Will a home compressor be able to get the tire back on bead?
i think you need one of those tools to get the pin out but its only like 2 dollars. as for the bead you can just put a ratchet strap around the tire and crank it down, then when you start filling the tire it will pop back into the bead.
Max cold pressure is 36 PSI front, 42 PSI rear. Many people ride a little lower PSI than this (especially in the twisties), but about 34/40 is a good general starting point
those are the numbers for max payload capacity, for example, if you're riding two up. I usually keep mine at 35(rear)/33(front) for street riding.
Or if you're fat like me and weigh about as much as 2 skinny people. :banghead:
tire pressure make such a big difference. I purchased my bike a little over a month ago and never checked the tire pressure after buying it. It wasnt until I did my oil change a few weeks ago that I decided to check my tire pressure, just for giggles...I was 8psi in the front and 11psi in the back. After pumping B016's to 34 in the front and back...its a completely different bike...and it CORNERS. I feel so much more comfortable on my bike... :+1: for checking tire pressure.
I check it every Friday night before I head off to find some twisties on the weekends. As others have been saying...as a VERY general rule of thumb that I use and is not applicable in all situations, low 30s for twisties, mid 30s for slabbin', upper 30's for a fully loaded bike.
I accidentally ran 28 in the front when it was cold and on a hard riding day. Ended up with a really weird grove/dip around the tire. Thought the bike felt weird.
1 - 20 of 20 Posts
