My bike was riding fine. I was riding it around for a few mins learning it,
But then when I put it back in the storage unit. I had to go over a lip and when I did that stalled it and since then it wouldn't start back up. It first it would crank, but then it just would click now I'm not even getting that. The battery is good the lights are bright the wires and connections are tight. I'm stumped now i looked in the owners manual and thought maybe it was flooded but that didn't work either .:banghead:
Just because the head lights are working fine does not mean the battery got to enough juice to get the fuel pump priming , the starter going .Th battery needs to get charged If you do not have a battery charger disconnect it off the bike & take if to any auto parts store such ad Pep Boys , Advance , Discount Auto ask them to load test the battery for you & if it's ok ask them to charge it
Reactions: Blurpee
are you in gear? kickstand kill switch? couple things to check quick/easily...
It's in neutral and I tried it with both the kick stand up and down I guess I'll take the battery to auto zone unless I can jump start it with my car?
Very important If you jump it with you Car make sure the Car's engine ain't running
Yeah it was the battery I jumped it and it started up
