1 - 8 of 8 Posts
push both buttons at the same time, then i think adjust changed the number you have selected and select moves to the next number.
Hold bth buttons down till the the numbers start blinking
the Adj will reset the hours , the reset will adj the minutes
what year rr is it ?? the 03 04 s had problems with the buttons falling out of the cluster under the rubber buttons you can take the rubber off and take 2 small screwdrivers or somthing else that fits and set them that way and then put the rubber back on ..
I had the same problems with the buttons falling out under the rubber. I had to take the front end off, and the cluster out to take it apart to fix it. So far so good, and yes you push both buttons down to set the clock.
1 - 8 of 8 Posts
