1 - 16 of 16 Posts
what possible ways can my cluster not turnon/show up
but my bike runs fine and everything?
could it be a fuse or something else?
i recently changed the subharness so it should work shouldnt?
please help i can be riding around like this =/
because theres was a chip in the blue plug (corner) so i had it replace
but trust me the bike runs and everything just no display on the cluster!! wtf is going on...
K
you've checked that you're getting power to each lead from the connector in the back with a multimeter?
could be a shot dash.
Your bike will run just fine without the cluster hooked up. Check the main lead plugging into the back of the cluster. Make sure it's plugged all the way in. Then check all of your fuses. Brother has his trackbike with no cluster. Works just fine. T
Discussion Starter #11
i will check that out!!
could there be any other possiblities?
do you think my signals would effect that cluster not showing up?
Seems like the cluster itself is the problem....it is not out of the question.
Did it work prior to switching the harness?
If so, you can confirm if it is your new harness by plugging back in the old one.
1 - 16 of 16 Posts
