1 - 12 of 12 Posts
Well I change my oil after recently purchasing my 03 and the clutch still has an occasional slight slip on very high revs!
Never done a clutch before,but looks like I’m going to have to soon. I’m not too bad on the spanners,but I’m no mechanic,is it a straight forward job or difficult and will I need to purchase a repair manual to do the job guys
Thanks
BOTM Winner 07/16
Watch out for the washers as you pull out the clutch cover.. one of them can fall very easily..
I found that having the bike on side stand (instead of paddock stand) gives a better angle so that the washers don't fall out when you pull the clutch cover off.
Ok I’ll keep an eye out on them.
I’ll replace the friction plates and steel plates and springs,is there a gasket on the 03 or is it a “liquid” gasket
It’s only done 23k Miles,but the previous owner did carry his wife as pillion. He never mentioned the clutch slipping so I’m just hoping there’s nothing else “hiding”
It's a pretty straight forward job.
The Honda service manual is pretty easy to find in PDF form. I would use that as a resource. If you can't find it shoot me a PM
My f4i has over 83,000 with at a very minimum 20,000 done 2up while riding very aggressive, still the original clutch. The previous owner didn't know how to ride. Pull your clutch and inspect before ordering a new one, make sure you need it.
Your probably right,he couldn’t ride correctly or the only other issue would be that he’s been using fully synthetic oil after reading these clutches prefer semi.
The only oil “these clutches prefer” is a motorcycle spec oil; doesn’t matter if it’s dino, synth or blended it will work just fine.
Don’t perpetuate incorrect info.
I've run various full synthetic oils for the last 50,000 miles
1 - 12 of 12 Posts
