I want to have it a little closer to the clipon. But the adjusters only adjust freeplay. How can I adjust the engagement point?
I don't see why not, my Pazzo's were the same for my '05 on the clutch side. I would double check with CRG to be sure though.
You still adjust the freeplay with the cable adjuster. The red tab on the lever adjusts the distance the lever is from the bar. You will be able to bring the lever closer to the bar without having a loose clutch cable.
