Going to diassembly my clutch and was reading through the manual. There is a part in the manual that says to unstake (disassemble) and stake(reassemble) the locknut. What does unstake/stake mean? sorry for the newb question
She was Holding The Magnifying Glass
There is a big nut holding the clutch on the shaft, the shaft has a notch out of it along the threads. To loosen the bolt you stick an awl where the lip of the bolt has been staked and pry in back into shape and to reinstall you tighten the bolt to torque specs and use a punch to re-stake the bolt. Not sure if any of this makes sense? I have reused many nuts that have been restaked and never hold a failure. But you make that call yourself.
