BOTM Winner Jan 2015
Hey everyone,
Bear with me on this one while I explain it.
Here's how it started;
A few days ago I took the levers off and and was going to get them powder coated, I ended up not doing it and so I put the levers back on.
Here's the problem: I know the grooves are supposed to face down on the adjusters, so in one position they are too tight, but if I loosen them up a full rotation so that they face down still, it's too loose.
I put the rear tire up on a stand and I've noticed that in both positions, with the clutch fully engaged, the rear tire won't move. However if I let out just a bit it starts to move and won't stop even after I pull the clutch back in. It will keep spinning unless I apply the rear brake. This happens much easier and to a bigger degree if I have it on the looser end of the two position options for the adjuster nut.
Is this normal and is it better to have the clutch in a tighter or looser position?Any advice or input is greatly appreciated. I'm completely new tinkering with bikes and feel really stupid.
BTW I have a '13 RR
Oh. I thought it was supposed to. Wow I feel dumb. Alrighty then...I'll just move along haha
