1 - 8 of 8 Posts
If a clutch lever goes "all the way back" with no play at all, it's not adjusted properly.
There should be 10-20mm if play in the lever.
If there is no play, the cable is too tight, and can cause clutch to slip. (Unless there is a spring or something in the clutch lever that takes up the lever slack, but I know the stocker doesn't have such a thing.)
i want my ASV levers :( do you adjust the cable from the clutch cover? may be you have to do that man. which color you go with?
rodrigo
1 - 8 of 8 Posts
