So i installed Yoyodyne clutch and idk whats going on, while riding the clutch lever gets loose and while downshifting gears it kinda taps the lever kinda like a click when the gear changes. Whats my problem?
Sent from Motorcycle.com App
I recommend sending OveRRev a PM with details of your problem.
thanks, I emailed yoyodyne I as told that lil tap is normal. Because stock clutch had a one piece hub and the slipper has a 2 piece hub, and the hub lifts up and hits the pressure plate which causes that lil tap.
I have a Yoyodyne clutch and it clicks when I shift or downshift. My clutch lever never gets loose though, not sure why yours would.
clutch is probably fvcked because you never ride
argument is invalid went for 3 rides already! hahahh just had to put everything together.
had to tighten it, I think since I changed my bars and everything I had to tighten it way more from the bottom adjustments. went for a spin the other day seemed nice and tight. My main concern was the click/tap on the lever thought maybe I put something wrong.
