1 - 2 of 2 Posts
What clutch kits do you track guys use? I'm going to replace my clutch while I have the motor out and replacing my transmission and I was curious what clutch you guys use and what springs? I was thinking of going with stiffer springs.
Running Honda genuine clutch & steel plates with my EVR slipper clutch but I had to remove the judder spring & plate along with the clutch plate at the back of the clutch stack, replaced it with the clutch plate for the front of the stack. Using EBC clutch springs as well.
1 - 2 of 2 Posts
