1 - 20 of 66 Posts
ok - flame me if this has been posted, I can not find it. my brother and is on me because I do not use the clutch except to take off, and come to a stop... really, this is all I have done for years! might have been my dirtbike day, but is it that bad? seriously, nothing like hammering it down a cog, and sliding it into the corner.
THANK GOD!!! I am going to google this question as well. print the answer and tattoo it on his nutz.. lol
K
Nope, perfectly fine on all associated parts. brother is wrong-o.
Post Whore Extraordinaire
dear lord, not another thread about this.
Most sportbikes are designed to allow for clutchless shifting. Preload the shifter while on the throttle, and just let off the throttle for a quick second, and you will shift as smooth as ever into the next gear.
K
manual cars are exactly the same way... only they're geared a bit taller so it takes a while to get the engine down to engage the next gear.
Do you down shift without it as well? Anyhow, if you really want to have some fun go pick up a dyno jet quick shifter. It allows me full throttle clutchless upshifts shifts. I had to get an ignition modual as well to make it work perfectly, but now I can bang through gears wide open without touching the clutch. I wont ride without one now.
Macho Office Monkey
Sounds like a blast but dangerious too you must be flying!!!
It really does not substaintially aggregate any wear and tear... so no biggie, clutches are for synchronizing the well rotating rotors in the engine ... so in theory all forms of shifting can be done without clutches if you understand and know the speed of the connecting rotors..
K
no! NO NO NO! The SOLE function of the clutch is to provide or remove power from the engine to the transmission. it has NOTHING to do with synchronizing gears.
exactly.. now how does power get added or remove? okay, maybe rotors ain't the correct word, bearings might be it.. I am not a mechanic but enough science have thought me that power just doesn't come from clutches... You are prolly using street talk.. maybe... I might not have the correct jargon but I sure do know what the mechanism of the clutches are involved in... Engines are engines... there hasn't been a drastic change in concept since the first combustion engine was produced..
i can clutchless upshift like butter but how do u downshift w/o the clutch? i know its possible isn't this dangerous because of the kickback. isn't that also why they invented slipper clutches?
1 - 20 of 66 Posts
