1 - 3 of 3 Posts
i know a few guys used to use this set on their f4i's so im wondering if it will work with the double r's. so does anyone use the front and rear stands from handy stands? if so did you get the bobin support ones (i assume those are used for spools) with no problems. also do their front stands work well. dont know much about stands, what are the advandages of using spools?
for 100bux for front and rear stands you cant beat it! http://www.handyindustries.com/webdeals.asp
tia,
mike
I use them and they are just fine for the price. I did end up buying a front straering head lift stand later on as I had to remove forks wich you cant do with the fork lift type.
1 - 3 of 3 Posts
