1 - 10 of 10 Posts
okay i need help from a computer person
so i spilled orange juice on my laptop shut it off and pulled out battery let it dry took off the top and cleaned the boards with a board cleaner to prevent corrosion but the keyboard is sealed and i cant clean the board of it and the end key keeps getting stuck on when im in a forum or anything so is there a program i can get to stop the function of that key i have windows vista
You say the keyboard is sealed?
Orange juice, coffee & milkshakes are the worst for keyboards
Can you remove the keyboard?
On the back of lots of laptops the k/b mounting screws are sometimes marked with a symbol. remove those & the k/b should be able to be removed. This will make cleaning it a lot easier.....
What model / make is it?
You can get another keyboard for it on ebay for like 20.00 and should be able to replace it in 10 min with a #1 phillips head screwdriver.
I have replaced the keyboard on every laptop I have owned due to keys wearing out and crap getting stuck down in between. All you do is do an internet search under your computer model for a repair manual or keyboard removal. You should find it to be free information. Most computer suppliers will supply that information also. Then I buy a replacement keyboard off Ebay for around $20. They are always easy to install, one ribbon cable, just a couple of tiny torx screws or so to pop it apart to get the keyboard out...cake. A beginner can do it...scale of 1-10 in terms of difficulty...3.
the cheapest i can find a new keyboard is for 60 bucks i took the keyboard off the comp and cleaned the computer but the keyboard part is all sealed underneath
thanks fior the program knight now i gotta find a free one lol
mission success guys i found a program that let me delete the key stroke from the registry, so thanks alot guys
Detach the keyboard and you usually can clean them with rubbing alcohol. Since there is nothing but a ribbon coord that attachs to the mobo to the keyboard easy removal and if you search once detached can run water over them to clean them...Keyboards are cheap replacements to...20...
1 - 10 of 10 Posts
