1 - 8 of 8 Posts
Long story short I am putting a 06 motor with harness in a 03 RR. I got everything together so far but I can;t find the plug for the coolant fan on the new harness. I didn;t know if it was a different connector or I am looking in the wrong place. Thanks
Even if someone could email a picture of a 05-06 cooling fan I can tell if its wrong or not. Maybe I can splice it in with new connectors?? Trying to get this bike going soon Please help. Thanks
so from what you showed me the 03-05 wiring harness are the same right? If that is the case I can just put the 03 in with the 06 ECU??? Hope this sounds right. Thanks so much for your help
I hope this info helps you out and no worries you are welcome
auto pm RowskiRR ( Eric ) i think he was in the same boat as yours
a great guy and will help you out
thanks again. I went through the wiring of the 06 harness. I think I found the plug by following the wire from the fan relay. It is a differnent color then the 03. I will pm him. I could prob get away with a pic of the wiring diagram for an 05-06 since I have the wiring for a 03-04. Getting excited trying to get this pig fired up this weekend!!!
1 - 8 of 8 Posts
