my bike has been leaking coolant on the left side, i looked at it and there is dried up coolant all over a hose from the water pump, i took the hose off and doesnt seem to have any cracks or anything. also the clasp isnt loose or broken at all. any ideas what it could be?
also it is not a gasket either because you can see that the leak is from the hose connected to the water pump but everything checks out.
Try running it in your driveway and see where it's coming from. I definitely wouldn't ride it until you solve the issue, your rear wheel may slip and cause an accident. Throw up some pics if you got a chance.
its not a crazy leak, it just gets on the side of my bike. although i didnt see any cracks in the hose, i changed it. ill see how this holds up and if it doesnt help ill deff post some pics
get a new hose for sure. It will never stop leaking from it untill you do so
okay so i changed the hose the leak was coming from and i leave all my fairings off with my bike on the stand. i went out to the garage today and saw this...
gasket?! any ideas?
