1 - 8 of 8 Posts
Alright I have a problem, my fan stopped turning on. It usualy gets to the normal 220 degrees mark and turns on but isnt anymore and was wondering if you guys have any idea.
One thing that might of caused this and I didnt think it did anything was. The other night I was leaving this parking lot, and since it was late, they put up a chain thing across the entrance, and I was goign out the entrance, cause it was closer, and didnt see the chain drooping down below, so I luckily it was drooping, and my front tire went right over then it got caught up behind my front tire and hit the front fairings. It didnt do much but did crack the front right side a little bit. I just thought it didnt do anything, everything seemed to be in check, but now my fan wont turn on. I dont know if it is has anythign to do with that, but that is the only thing that has happened to my bike.
So if anyone has any suggestions on things i could check i would really appreciate it. Thanks alot.
Katon
Check your fuses first, the most common thing that would cause this issue.
Bike Of The Month - 09/05
Disconnect the ground whire from the fan.... and touch the radiator or something on the bike with grounded. If the fan starts then it's ok and you should check the fuses and the relay. If the fan doesn't work then its the fan that it not working.
Over the berm, and thru the woods, to grandmothers
Check to make sure you didn't push the radiator into the fan.
Thanks guys for all the help. I am goign to look into it. I sure hope i didnt push the radiator into the fan. I am not to good with that stuff, so hopefully it is somewhat obvious to me. Thanks
Katon
Well I fixed it. It ended up being that the radiator was pushed into the fan. But now I got it working. Thanks alot guys.
Katon
1 - 8 of 8 Posts
