1 - 13 of 13 Posts
hello, i need your help. so i was trying to get the licence plate light on. i accidently cut out the taillight wires, so i just tucked in the wire to the harness. " taillight works. then i cut off the licence harness and all the lights worked. later i tried to start my bike and all i hear is the battery rumbling. after a whilte the lights dim. what did i do? bike wont start and i need help !
it seems your battery has drained itself which probably happened from a short. If you have ay wire exposed or connected incorrectly and making a circuit it will drain your battery. Check all your connection again and make sure everything is properly insulated. If you find nothing make sure you have not connected a hot wire to a ground, that would short your system.
ok pictures up. again after connecting every back where it should go, the light work. but now when i turn on the switch i hear the buzz. and when i start i dont hear the engine wanting to start, all i hear is the battery tryna start ( i dont know if that mad sense), then after 2-3 tries the lights dim =(
btw when i try to start ,the battery sounds energetic. its just that i dont hear the engine trying to start. i feel like if i charge the battery it would have the same affect. or am i wrong?
the pic is kinda small, but it looks like you have bare wires, or you've hooked something up to a direct short. havy you tried pulling the taillight fuse and seeing if it'll start?
yea pic is small, tried bigger but it says files to large. the picture shows just that i cut the wire off its hardness (hopefully nothing serious). where are the fuse box located and which ones the tail light?
fuse box is located in a rubber cover on the left side of the bike. i don't remember if you have to remove the fairing or not. it'll be labeled tail light.
just checked, all fuses are good. lights good until i turn on the switch and start up the bike, the noise comes around the battery area. but no engine noise =(
I Am a Ticket Magnet
sounds to me like a short as welll........... make sure all of your wires are connected securely or capped off... you may have shorted out the harness... which would suck... i shorted out my front subharness a while back because one of my blinker wires came loose and grounded out....
1 - 13 of 13 Posts
