Propped up the phone dock how I felt was a decent angle.
Secured JUST the wing nuts in place with some sticks to prop and hot glue.
After removing the screws and dock so just the wingnuts showed. I then threaded in some screws to keep the threads clean. And used a fiberglass reinforced body filler to secure the wing nuts in place.
Then I secured the dock back in place to the new secured wing nuts. I actually went with pipe cleaners on this because of there being so many angles and small lengths, it seemed to work really well. I used more small diameter wood dowels and pipe cleaner to outline the phone dock.
After removing the phone dock i glued fabric from the edges of the fiberglass mold to the pipe cleaners and wood. Looks a little sloppy :/
I then fiber glassed over the fabric with 2 layers of fiberglass. Something I learned while working with fiberglass that helps in the finishing stage is to be very generous with the resin over the final layer of fiberglass chop mat. It makes it a lot easier to sand.
Again when it was partially dry I cut the edges with a razor blade so I had to sand less when it cured fully. After it cured the sanding began. Don't even bother trying to do it by hand, it's not worth it. Find someone with an electric or air sander.
very rough fit..
After lots of sanding to get it to the rough shape I wanted I gave her a coat of bondo and did a quick sand. Then gave a rough outline of the phone dock to dremel out and get the opening back big enough to fit the dock.
very rough fit..
