1 - 13 of 13 Posts
Hi guys I recently put diesel into my bike by mistake :spank:
I didnt start it and drained the tank. After that I put in a new fill and went for a spin but it kept on cutting out at low revs. I thought this might be the plugs so I changed them and did the oil and filter while I was at it. But still have the same problem. I should mention the bike also has a power commander on it.
I was hoping someone might know why this is happening?
Cheers
Im not sure what RPM it is cutting out at but Im guessing about 2-3000
Il take ot for a spin when im back home and let you know
No (sorry I should have mentioned that) it only cuts out when you put it in gear. I have to give it a bit of a rev when I turn it on but then it will tick over fine.
Just a quick update. I took the bike out for a spin at the weekend. For about 5-10 mins it was driving fine. Then the cutting out started again. It is happening when the revs dip below 2000rpm
Anyone have an ideas please?
It is idling around around 1500 but I think its a bit too low. But the bike will tick over perfect when you turn it on but then when your driving it, it will cut out when the rves drop in any gear not just first. Could that be a sign that it is idling at too low of an RPM?
Damn idk lol I just remember my gsxr used to cut out cuz it was only idling around 1000-1200 rpms. Try adjusting it to abt 1800 at idle n see if that works
TBR33ZY ur a legend thanks a mill adjusted the idle rpm and its running fine. Just back in from a spin on a wet horrible day but im happy out now that it is back working 100% :)
1 - 13 of 13 Posts
