1 - 12 of 12 Posts
So I just recently bought this 2008 CBR600RR with only 4,000 miles on it and this is the ONLY...the only thing I could find bad on this thing, not even some rust. My question isssss...is this possible to repair...whether personally or in a shop or will I just have to paint over it and deal with it?
Thanks
well you can replace that cover. You can get some after market ones or just the OEM one. I dont think its too hard to do, but you have to drain some fluids first...
Only about $120 in parts to replace it. Make sure they use Hondabond HT and not Hondabond 4 as a liquid gasket. Wait until you need an oil change since it has to get drained during the job to replace the cover.
I'm a pretty lady!!!
Nothing that bubble gum, band aids, spit can't fix!
Like the rest of the peeps said, you canz replace it! I did mine not too hard of a yob to do.
i had the same thing from the previous owner. i just painted over it. took a while to try and blend a paint mixture to look right.
I understand that I can replace the cap but what about the damage the is not on the cap around the outside!?! I don't see any part of that which can be replaced.
It's called the clutch cover and yes, for like $120 and a half hour of you time during the next oil change can be replaced.
Look at the exploded view on a micro fiche say at Ron Ayers or some place like that and you'll see.
Mike
You'll have to replace te complete cover... Clutch + timing ispection cover... and you are good to go...
Still, I would just put a protecting case over it...
R&G... for example ... or even aftermarket Carbon fibre cover...
1 - 12 of 12 Posts
