Hi All
Recently had a off and damaged the front nose cone.
Got the bike back and stripped it down not as bad as I thought it would be..
Only problem I have come across is the dash cluster is not working it lights up but the
MPH / TEMP / MILEGAE / FUEL / SPEEDO NEEDLE ARE NOT WORKING OR DISPLAYING, had water damage
Gave it a to a local electriction who has replaced a few things.!!! still not working:crying:
I have treid another clock off a friend and all works.!!!
I have attach photo if anyone can help me or give me some idea
Thanks in advance
Define "had water damage"?
I don't think I can help, other than to suggest that you thoroughly dry it out. There are numerous ways to dry it, but whatever way you use, open up and expose as much of the insides as possible, and don't overtemp anything (don't melt it!). Best way may be to get a very low humidity environment, and use a dry heat up to about 130 deg F or so. A fan directed at the speedo will speed up the process. You also could have fried a component on the circuit board, in which case, this won't help. Good luck.
It rained somehow got water in the clock when I collected from the garage but did not relised till a few days later..
I have taken apart left it to dry and ended up with no display!!!!!!
