221 - 235 of 235 Posts
BOTM Winner 07/16
If you use multimeter to check for connection between the plug lin and the capacitor, do you get a full circuit? If not, they are not connected properly.
If yes, it could be something else that throws the code.
Try resetting the ecu by removing the battery for 30 seconds.
I have tried to put the servo motor on. and no FI light come on.
I have tried to reset the fault codes with the DLC plug.
-I will try removing the battery, did not know that will reset the codes.
Still nothing :(
i heard from others who tried the same resistors and capicator that the FI lights was on for the first couple of time they tried it but suddently it turned off.
So i am out of ideas. I think i try to fitted on and try to see if it turns off after a couple of trackdays. my alternative is to put on the servo motor again :(
No I have not. you are right i should :)
Next thing to do measure the resistors.
I just assumed that the label was right. But I ordered them from HongKong so who knows :)
did you meter the resistors can cap to verify they are good and the same values as recommended?
"unfortunately" it was the correct resistor. So this is not the reason.
I do not think it has anything to do with it. But mine is a EU model. In this regard i think EU and US models are the same?
This is really driving me crazy.
did you meter the capacitor? i thought i implied that in my first comment.
you likely have a bad component somewhere.
heres mine, been running solid since 2011, installed on 2009 cbr 600rr
about to build another hi quality unit for my 2011 cbr 1000rr
Thanks so much for the sketch. I ordered the resistors and capacitor off Amazon 6 months ago and was able to make this last weekend. It works great with no issues.
