Marshall said:
I have a 2004 and the high beam switch nevers go off.
Marshall said:Get a battery tender, keep your bike plugged in while it's parked at home. Keep your battery in tip top condition.
I think this problem has been totally misunderstood and falsely blamed on the high beams. As Knight points out, it's the R/R being too close to the headers that's causing the problem. The high beams are just a symptom of the cause.FACTION95Si said:I think this pretty much sums it up. I have an 03. Back in 2003 there were threads about this issue all the time.
Come on man! In less than 30 minutes you can fix your problem. That R/R is easy as hell to swap out and if it's good it'll most likely solve the problem. If you continue to run the bad R/R on the new battery it will damage that one also. Get to it!~BLACK ICE~ said:my '03 has had that problem from the get-go. when i first purchased it the dealer told me that i was only able to use the high beams on the freeway.. hahahahaha
i have purchased a new rectifier but am too lazy to install it.
i would run the highbeams 24/7 if i didnt have that problem. i did although purchase a new battery.
..... oh and yes this is like the 3459834029833498 post about high beams.
If you have a multimeter I can show you how to test it yourself. Pretty simple actually.FACTION95Si said:Knightslugger I havn't had it tested.
Is this something the Honda dealer will do under warranty?
It almost always ends up like this...FACTION95Si said:BTW this thread is on its 4th page. Anyone feel like this is beating a dead horse?
I can't find a picture or description of the Stay and the Collar. Who said you needed those and why? All you should need is the R/R. Make sure your battery is good before you install the R/R. If the battery is bad then get a new one.Alex_RR said:after searching the problem out, it looks like the culprit is not the high beams or the battery. Can someone please confirm that the parts listed in the pic are indeed what I need to solve the problem?
Thanks for the info guys
Is this with the Battery Plus battery? Have you had the battery load tested?Alex_RR said:I almost have the exact same measurments with my battery, except when I have the highbeams on at idle the battery voltage slowly starts dropping and keeps dropping. If I have the highbeams on and run the engine at 5000rpm than my battery volts climb up to 13.92
this is on an 03 with 3700 miles
