I think this pretty much sums it up. I have an 03. Back in 2003 there were threads about this issue all the time.Toobs said:
I think this pretty much sums it up. I have an 03. Back in 2003 there were threads about this issue all the time.Toobs said:2003- Yes
2004- Not sure. Maybe Yes (if its same as 2003)
2005- Nope
2006- Nope
I think this problem has been totally misunderstood and falsely blamed on the high beams. As Knight points out, it's the R/R being too close to the headers that's causing the problem. The high beams are just a symptom of the cause.FACTION95Si said:I think this pretty much sums it up. I have an 03. Back in 2003 there were threads about this issue all the time.
Can you please explain this with details?hessogood said:Let me just point out for you, there are 22 (23 including this) post in this thread. All of them are opinion with the exception of one which is fact.
I'm intentionally not elaborating so that I don't have to deal with being flamed and challenged. Use the search function there are plenty of threads for this. Anyone going against the masses of " i use my high beams " is put out.shamster said:Can you please explain this with details?
With all due respect, you should elaborate if you make concrete statements that you say are fact, over opinion.hessogood said:I'm intentionally not elaborating so that I don't have to deal with being flamed and challenged. Use the search function there are plenty of threads for this. Anyone going against the masses of " i use my high beams " is put out.
shamster said:Well, I'm sure everyone can agree that they use more power. To the point of killing your battery prematurely is another point.
Plus, if you're so sure that what you say is absolutely correct, you should have nothing to fear anyway. But the fact is that people get away with using highbeams for prolonged periods of time with no ill effects. That alone makes any "fact" not so absolute.
The charging and consumed voltage is dependent on many factors. The temperature of the rectifier, the speed of the stator, what is being drawn off the battery..etc. Let the bike run until it gets hot enough for the fan to turn on and tell me if you see your high beams dim. What does that tell you about the draw on the battery? Do you know the chemistry in how a battery works and why a battery will stop working? I've been through it before with many topics on this site, just because the majority says so doesn't make it true. Does it matter that I've been on two wheels since I was 9 or I have a degree in electrical engineering from one of the top schools in the country? Of course not, because you haven't had a problem yet.Knightslugger said:How much amprge does the generator put out?
How much does the bike draw?
the subtraction of those two will tell you irrefutably if they do or do not overdraw the power generation system.
Nobody said a leg stand is better than stem stand. And we all know if you need to do work with your forks, you need a stem stand. Guess what? A stem stand often costs more though. A good fork stand is sufficient enough for those who just do very basic maintenance. And sorry, but I can assure you my bike is not going anywhere off the stands in my garage. I would seriously have to exert a good amount of intentional force to knock the bike over while it's on the stands in my garage.hessogood said:I've given evidence. The hanging off is a demonstration on stability, even the best quality leg stand is less stable the the worst pin type. The stability and versatility of pin stand are the reasons that it's superior to the leg stand. If you want to change your front wheel without removing the calipers you need to remove the fender and spin the fork tubes. You can't do that with a leg stand. You can't remove the fork legs, you can't adjust the ride height of the forks. So becasue you bought a leg stand and not a pin stand, well it must be a great stand huh? I bet because you ride a honda it's the best bike made too?
That doesn't tell me anything other than it takes quite a bit of amparge to get the fan to turn, but once it's turning stready, load is reduced.hessogood said:The charging and consumed voltage is dependent on many factors. The temperature of the rectifier, the speed of the stator, what is being drawn off the battery..etc. Let the bike run until it gets hot enough for the fan to turn on and tell me if you see your high beams dim. What does that tell you about the draw on the battery?
Well said. I certainly do not have an electrical engineering degree, and I'll be the first to admit my knowledge with electrical systems is pretty sub-par. I certainly am not going to accuse someone of being wrong when I'm not that knowledgable on the topic myself, but it seems like it's too difficult for some to back up their supposed knowledge.Knightslugger said:if we cannot produce this information, then what more do we have than common knowledge? produce some facts or step off your soap box. so far all i've heard is "I'm an electrical enginier", "I've been on two wheels since i was 9", and "Becasue i said so". nothing substantal.
