1 - 20 of 22 Posts
I just got rid of my gixxer for an 04 doubleR, and when I down shift, as soon as I let go of the clutch, the rear wheel skids for a split second. this is the same bike I was taught to ride on bout 2 years ago and didnt do it then. does anyone know what this could be?
none of the 600rr's have slipper clutches.. so unless you rev match its gonna do that in the higher rpms. And the only explanation I have for the other bike not doing it is either it had an aftermarket slipper in it, or a beat to **** clutch.
Make sure you give it a little throttle when you let go of the clutch, make sure the clutch is properly adjusted, and make sure the chain tension is right.
+1
if you're having a bit of trouble up-shifting, or if it feels like you have to put more effort than needed, then maybe the pinch clamp for the shift-rod may be off by a tooth.
Also check that the rear tire is not over inflated as this will also contribute to rear wheel slippage.
You really should learn to blip the throttle. It not only is better for more stable downshifts, but it also sounds cool! I can't believe I rode around for over a year with no idea how to do it.
When street riding, I don't downshift till my motor is like 3K RPMs. So even if I do a really slow downshift where my engine slows all the way to idle, Letting the clutch out doesn't caust the tire to skid. Also, I never use first gear to engine brake. I'll shift down to second then to neutral and use the brakes only from there.
blimp/revmatch when you downshift. When you're under heavy braking and downshifting at the same time you're still going to get the chatter/lockup. I see it all the time at the track when the fast guys are going to a hairpin turn after a long straight you can see the rear get slippery before they turn the bike in. pretty badass looking, but probably scary if you're not used to it.
hehe... rev-match it man. Then after you get good (should take 5 minutes.) Learn to downshift while braking AND rev-matching! Very useful skills to learn!
I usually don't rev match unless I'm above 7K rpms. Anything below that, and I just ease the clutch out. Of course..this might entirely change once I have the opportunity to take her to the track...
One thing I have noticed is how much less you need to blip on this bike vs a vtwin. It's amazing how little engine braking there is.
1 - 20 of 22 Posts
