Hi all, looking for fitment specs of the drive sprocket on the output shaft
With the chain completely off, i noticed it floats axially a lot relative to the shaft, something like 1-2 mm, and also it rocks side-to-side like crazy. The washer is there, but the bolt/washer seem to be tight on a shaft shoulder or something, not on the sprocket.
Is this normal?
is it the case where the drive sprocket floats to offset-align itself with the wheel sprocket? If so, how much is too little or too much?
I get that sprocket/kits come in different thicknesses but I assumed it only applied at the teeth, not near the bore/spline as well. or is it the case?
or is it the case where the mechanic might have thrown in a wrong or cheapcrap sprocket kit?
digging the older threads i found a nico quote: "The after market ones are generally a little looser than the OEM ones, but not enough to cause problems. " which is assuring , but i'd be grateful for some numbers.
Also seems a good idea to grease the splines, is it a thing? its bone dry and the manual doesn't say anything about it...any help is appreciated
Is this normal?
