1 - 8 of 8 Posts
Hey guys.
So a few days ago I dropped the bike on the left side in a parking lot. The way it happened was kind of weird, the bike went down pretty hard, but I was only doing about 3-4 mph. Picked it back up, rode it home, thought I smelled some coolant but my sense of smell isn't too great so I didn't know if I was being paranoid.
The next morning I started the bike up and sat on it but answered a few text messages before I started moving and suddenly noticed a cloud of coolant steam (definitely smelled like coolant), and noticed a couple drops of coolant on the left case cover, but could not identify where it was coming from. It almost seemed like it was coming out of the case cover but I'm pretty sure that doesn't make sense lol. Rode it around to see if I could make the leak more obvious while carefully watching the temp, and it never overheated, and the visible leak actually stopped completely. Now I can only smell coolant.
I'm new to working on bikes so I don't really know where anything is on the engine, I havnt even found the water pump or anything. All I see is a spider web of coolant hoses. Besides the hoses is there anything on the left side of the engine that would leak coolant? I really don't see many possible places.
Thanks in advance.
You got to take both side middle fairings off to inspect the bike parts / hoses and make sure there is no damage to Radiator , Coolant Reservoir bottle or any of the hoses on both side of the bike . Do not assume anything just because symptoms has changed or improved all together dealing with overheated engine while on the road is no fun at all overheatng can lead to serious engine complications
water pump is on the left side. Like Moe said, take the fairings off and inspect it to see if you can see where the coolant is leaking. It also might have just been the overflow hose dumping coolant from the bike laying on it's side
Thats what I was thinking but this happened the next day. Im running the bike right now and checking for leaks, i still can't find the water pump but i see some residue under the hoses so maybe i just have a leaky hose.
I'm checking the hoses on the left side of the bike right now. Radiator and reservoir are fine.
Aaaaand score. The steel pipe that goes from the radiator to the engine has a small section of rubber hose that connects it to the engine. Seems like its leaking from there. Not sure if the clamp itself is leaking so I'm just gonna go buy a hose and replace it.
Great job so far :shakehand
left side of the bike, water pump is the part in the center of the pic with the 2 hoses going into it
1 - 8 of 8 Posts
