1 - 20 of 38 Posts
Baseline:
Max HP = 98.69 @ 13.5k
Max torque = 41.76 ft - lbs @ 11k
Dyno'd:
Max HP = 107.04 @ 13.5k
Max torque = 45.31 ft - lbs @ 11k
Akrapovic Hex slipon w/BMC filter
Baseline:
Dyno'd:
Wow, those are some great gains!
Is that baseline with the Akra and then tuned, or baseline with a stock vs. tuned Akra? I'd be really interested to see the actual curves.
Wow those are sweet numbers...
Doesn't hurt that the exhaust is the sexiest looking/sounding. (imho)
If i can scan the curves I'll post them up.
Basically the tuned curve has gains everywhere except @ 2k rpm. ^^"
thats awesome, i wonder my full akra will perform? where in socal did you get it tuned? how much did this place charge if you dont mind me asking? ill be putting a pc3 in next week and hopefully get it mapped as well.
Mach1 in Newport Beach. They ask about $350. Buy your own O2 eliminator kit from dynojet because they'll charge you $20 if you don't. Talk to Jim.
Baseline with akra and then tuned.
I didn't have enough $ for a stock pull. :(
How was it tuned: you have a PCIII installed.
With a slip-on, PCIII and a BMC filter that's about what I'd expect. You'll probably see about 111-113 rwhp with a full system. Post the charts and tell us about the run conditions.
Otherwise there's no change your bike gained 7-9 hp with just a slip on. 3-4 would be more likely.
AZN you got the full hex akra? I finally got a chance to ride mine, and it was at a track day at Barber...man what a difference, it felt like a new bike...
Glad the bike runs good now but its not really known what gains the pipe made then cuz he never got a stock run. Was just good mapping by the tuner.
For all we know the stock bike could of made 110 hp on that dyno - then went down to 98 hp after the pipe instalation and no map- then made 107 hp after tuning. Until then you never know what the pipe made
HP aside, the feel is definately better. More responsive and way more torque. I can't keep the front wheel down like i used to. I need to eat more.
Discussion Starter #17
True but i've seen stock runs on the 05/06 rr and they're usually around 100-103. Either way i'm happy with the tuning.
Friend,
having a few more ponies and 5 ft lbs more torque will not turn your bike into an RCV...if you can't keep the front wheel down you better check your rear shock and make sure it still works!
Nah, dude i ended up getting the older style oval system. Tt was such an awesome deal i couldnt pass it up.
Yes, I understand it takes a pc3 to tune but my point was from my understanding you can't get the proper A/f ratio with the catalytic converter intact. You either had to get them out some how or go to a full system. The cats won't allow you to measure the values correctly to get it properly tuned. It makes sense to me but I could be wrong.
Where's birdman when you need him???????
1 - 20 of 38 Posts
