1 - 20 of 27 Posts
Figured you guys would appreciate this more than others! Not sure if you have followed our story of this bike or not but it holds the current record and we were set to go back last year to Bonneville when it got stolen the day before we were leaving. Well, we got it back 2 months later and it needed some TLC. Here is a recent pic and we should have it up on the dyno later this week. I will post some dyno graphs when we have it. Last time is made 240hp but we now have a better boost controller so I hope to get it down to around 200hp, wheel spin is a bitch!! We will post a story on the site soon!
They actually put alot of work into making it streetable. Installed CBR1000 forks and new shock, made new dogbones, installed frame sliders??, rhino lined all the bodywork. Funny this is that they removed the Power Commander so it would have been running horribly as we have much larger injectors and higher fuel pressure!!! They actually threw a chain but luckily it did not destroy the engine cases.
interested in seeing the dyno graph. my buddy has gsxr100 turbo hes getting tuned today 93 oct gas at 4 psi and 117 oct race gas at 10 Psi.
They being the people that stole it?
Wow, how much work does it take to make a 600RR produce 200 - 240HP? That's insane.
Discussion Starter #11
Thanks!! IHI turbo with 15lbs of boost. The intercooler is also key to keep it from melting down and adds 15-20hp instantly. First year we went we had a stock valve come apart which destroyed the engine. We are now using 1 piece valves so hopefully this doesn't happen again.
Discussion Starter #12 (Edited)
Almost done tuning it. This graph is with 13lbs of boost and WITHOUT the intercooler turned on. You can see we have some wheel slip going on. Will turn up the boost next week and make another run.
Oh yeah, this is with only a PCV connected to the lowers. No adjustment on the uppers.
Just got back from Bonneville - Honda CBR600RR is the first 600cc open wheel motorcycle to go over 200mph. We now have a record of 206.015!! Top speed of 209mph. Bike made 6 passes and still runs like a champ! There is an Australian team going to the BUB event to try and beat this so if they do we will go back in October and turn up the boost!!
That's awesome! Congrats!
Did you make changes to the transmission to get that fast or was it only sprocket changes? What sprocket are being used?
hey congrats on the record, have a question about how they recovered the bike though? did they catch the thieves or was it just found etc, can you shed some light?
fast03600rr
that bike is nice looking guys!! thats an awesome record for a 600. did the 17 front bolt right on or did you have to do some clearancing for it?
1 - 20 of 27 Posts
