1 - 1 of 1 Posts
Bought a e-racings set off ebay for my 03 600rr. test fitting it and the tail is a pain in the @$$. I removed the plastic in the subframe and it is still a tight fit. Are you supose to trim the plastic or just leave it out???? If leaving it out is there anything to do about mounting your power commander???? or heat problems for that matter???? Also where do you mount your rear brake resevor...
Thanks, D.
1 - 1 of 1 Posts
