i have found an 05 600rr for sale that just needs a computer, i have a wrecked 03 that i am parting out and still have the computer and wire harness. could i use my stuff on the 05 bike and everything work or what would i need to do ? thanks
not sure but im guessing the ECU. that is all the ad said and awaiting the response from the guy. i have both so either way if the ecu is interchangeable i can do that or the cluster also. its a pretty good deal and dont want to pass it up if i have the part that will work.
the ecu and wire harnesses's need to be the same
so if you are using an 05-06 wiring harness, you need an 05-06 ecu, 05-06 spark plug harness, and 05-06 headlight/gauge harness.
also, i'm not sure if you can swap all the 03 wiring to an 05 motor tho...
if you need just an 05-06 ecu, i have one for sale. pm me if you are interested. i also have the 05-06 main harness, and the 05-06 spark plug harness...
best of luck either way
You need the 05-06 ecu. You can use the 03-04 gear with it but that seems a little silly... lots of work, and you would be going backwards...
