Ok, I just had the front clip off the bike to wire in some led mirrors and install my HID kit. I also deciced to wire in a new flasher relay to avoid resistors everywhere. Everything works fine on the left side of the bike, all blinkers work, and have a normal flash rate. The right side of the bike is a different story. All the signals on this side (mirrors, flushies, and trip's pass peg signals) are dimmly lit. Very dim. If i use the signal for that side it blows the fuse. So what should I be looking for when i t ear everything back apart?
Sounds like a short to ground. Make sure you have your +/- leads correctly wired and not swapped.
I hope thats all it is.
?????????????????? anyone else???
Something on the right side is grounded or has a short... Double check all the wires and connections...
