1 - 2 of 2 Posts
05 600rr
the dash went out so i replaced the turn signal fuse, but the left turn signals front and back and the one on the dash dont light up.check the positive wire on the turn signal and no power seems to go to it unless i power the right turn signal.
any ideas
i have the whle bike apart trying to figure it out
thanks
Did you check the correct wire ?
Solid color(Orange) wire is turn signal wire
stripped with White is running light wire , Green is ground
Do you have stock turn signals or after market (Led) ?
1 - 2 of 2 Posts
