1 - 2 of 2 Posts
I am in the process of swapping out my 09 ECU for a 07/08 ECU , this requires moving one wire on the ecu harness to a different slot on the harness. So I managed to get out the pin from the harness but now it's not clipping back in , afraid I mangled the pin too bad trying to get it out . This was my first time ever doing this , learning .
Either I am doing something wrong putting the wire back in
or
I damaged the pin/clip
Does anyone know the pin/clip model if I need to replace it
Thanks
or
Thanks
Honda Motorcycle 33 pin Sumitomo ECU-ECM-PCM Connectors
Scroll down that page and you can buy just the terminals instead of the whole housing. I think they have a $5 minimum order though.
1 - 2 of 2 Posts
