1 - 11 of 11 Posts
I just installed a Yosh ti yesterday and now my turn signals won't work. When I try them, all I get is both lights flashin. I disconnetted the battery to reset the ecu, but no luck. Anyone have any insight why I'm gettin the emergency light. I tried searching and again, no luck.
She thinks my tractor's sexy, it really turns her
sweet, was it up, up, down, down, left, right, left, right, B, A, B, A????
check your wireing, maybe something got crossed or disconnected during the install. also try turning the signals on while the motor is running. I installed a CA integrated tail light and greggs in the front and they don't blink unless the motor is running.
Okay, this is strange. I check the wiring and they are good. The weird thing is when I disconnet one turn signal the other one works fine, and vise versa. But when I have both connected, the turns become both come on and flashe.
Charge your battery. Seriously.
You blinkers are run in a series loop. Both front and rear are on the loop. Do you have the stock blinkers still?
1 - 11 of 11 Posts
