So i was in the process of taking out the frame from the engine and there were 2 spacers that came off the top bolt. both have different widths. I was wondering if anyone knew which one goes to which side? thanks!!!
Look at the pictures in the manual (that you should be using for torque specs at the very least). It can also only go in one way. If you look at the bottom of the frame and how the mounting point is closer towards the center than the other it will give you a hint (left side has the longer spacer)
cool, thanks for the helpful tip. i just took it apart, i do plan to get the manual for the torque specs when i put it back together. do you know a link where i can purchase the manual. I heard most people uses the clymer one. but im wondering if getting the original Honda Service Manual is better...?
cant be a 07 those are the same width... maybe its an 03-06
