BOTM Winner 10/14
Hey there,
Got my engine finally up and running now,
so it's now waiting for my fairing to arrive.
BUT untill then I need to get all my accesoires on
SOOO first of all my GIpro DS-Series is not seem to work?
It is plugged into the red socket, the one near the battery.
But the GIpro is not even going on or showing anything.. am i missing something out?
2nd of all
there is this box I have on my bike, it came with it when i bought it back then.
but I dont know what it is and where to connect it.
It only says ACUMEN.
3rd problem..
I got a Alarm setup from SPY with a Remote start option.
its all wired up and my alarm is working superb!
but the remote start does not work.
If i turn it on by key, the fuel cut off relay gets powered.
but when i do it with the remote it does not get powered.
the starter is working with the remote but it does not get fuel because the relay is not powered..
I don't have a HISS system on my bike as far as i know, my key is flat, So I am not quite sure if I have a Immobilizer or not.
Because when turned on with the key it works flawless but without getting the key on ACC on, the fuel cut relay is not working and you can't hear the fuel pump
thanks in advance!!
BOTM Winner 10/14
For problem #3 you may inbox me instead of writing here because of anti theft information
And about #2, i have been told it is a flasher relay so my led signal flashers will flash normal speed.
BOTM Winner 05/15
You're correct on #2, no clue on #3.
As for #1, did you go through the learning program for the gear indicator? Even though it's plug and play, it still needs to be programmed. I know my PZ Racing GI won't register without being programmed.
BOTM Winner 10/14
Hmm problem #2 is fixed,
For #1
I can't get the Gi do anything, there is no sign of it coming alive.
For #3
The wire to my pcm gets with key 9v
Without key 12v
Could this be a possible problem?
