I have a noise on my 05 600rr has 14000 miles on it, the noise is intermittent and only happens on cold start/neutral for around 30secs to a minute then it's gone. It comes from the rear of the engine near the rear shock and the best way I can describe it is a rotating, slow paced, growling/droning noise. Performance wise it's fine all gears select how they should oil is changed every 2000miles it's very well looked after. And ideas you wonderful lot
It could be a couple of things. Top end chatter is common due to lack of lubrication during a cold start up. But you said its coming from the rear.. Does the noise increase if you rev the bike??
I don't apply throttle until it's warm it almost sounds like a pulley going bad in a car of a bearing but the oil was clean when drained a few silver spec but I believe this is normal? And it goes away once the bike gets up to temp
