1 - 3 of 3 Posts
Sounds like I have a blown head gasket, pulled the plugs , it doesnt seem like much compression, dont have a fitting for that small of a plug hole, will look for one tomorrow, does the 600rr have any problems with head gaskets, or is there an easy way to track this down , just looking for an easy way to find the problem, its an 2003, somebody help the boy
If you got a blown head gasket then you will have murky oil
( anti freeze mixed with oil ) so dump the oil and see what it
looks like , a compression test would be next in line keep
us posted and best of luck
In addition to what Moe said your cooling system can become pressurized as well. Look at the overflow tank with the engine running to see if there are an abnormal amount of bubbles coming up.
No, head gaskets have not been a regular problem.
1 - 3 of 3 Posts
