1 - 14 of 14 Posts
About 5 miles into my ride home, I pulled away from intersection at an easy pace. I was about 2 seconds into 6th when bike stopped pulling and engine reved up. I downshifted to 5th and all was good. Back to 6th and all worked. What can cause this?
bike was pulling after shifting to 6th for a couple of seconds. No aftermarket levers. I'm stumped. Will check bike over tomorrow. Thanks for input.
You hit a false neutral between fifth and sixth. it happens. No big deal. Make sure you are very deliberate with your foot when upshifting. You can be quick, but it's gotta be deliberate if that makes sense.
^ yep you popped out of 6th into a false neutral - just what Jim said - try to make your shifts more pronounced.
I'm with Jim as well... by deliberate he means make sure you feel it engage all of the way, which may require a little more force, and probably a bit more movement with you foot.
this, i bet there was a probably a clunk or a bang in there some where too.
:+1:
:+1:
:+1:
LoL
1 - 14 of 14 Posts
