1 - 15 of 15 Posts
I took my plastics off today...put the bike back without the plastics...now the bike WON'T start...it'll click but won't start...please help!
- D
Is your tip sensor installed right? It's a small box between the headlights that plugs into your electrical system. If it's upside down or just unplugged your bike will not start. Hope this helps.
J
so forget that the actual guy is not a mechanic, but hey he's a friend of a mechanic, so he must know something right?
LOL j/k
make sure it's not in a gear with the kickstand down....LOL
Stop/run switch
what else did you do? just take off and re-install the plastics?
Discussion Starter · #7 ·
all i did was take off the plastics...
i can't hear the high-pitched noise (which is the fuel pump) right before you start the bike...
any other ideas?
- D
please tell what the problem was I am having the same problem with mine
BAS (bank angle sensor) must be in the upright position.......and yes make sure your kickstand is not down.
bike is at honda dealer and they are stumped the fuel pump isnt getting juice for some reason they thought it was a easy fix(pinched wire) but it isnt the angle sensor was upright it doesnt make any sense cause the bike started before easily the dealer said they jumped the pump and it started so they know everything works they said it seems to be loosing juice somewhere or something the pump wont even cut on unless its jumped
G
well jesus, get someone else to diagnose the bike then. if the pump works when it's bridged, start going down the lines until you find the connection that isn't getting power/continuity!
good grief! Where do they get these grease monkey techs from?!
1 - 15 of 15 Posts
