1 - 10 of 10 Posts
TurtlesScout
is it possible to replace just my stock canister with a aftermarket??? or do i have to replace the mid pipe to?
stock can and pipe are welded together, while it could be cut apart to use with a random can, it is not advised since used exhausts can be had for $300 or less.
TurtlesScout
because im talking to some one witha hindle can for 160. would i not get the preformance when i put the air filter and pcII thing?
aahh newbies.... i remember those days. Save your money and get a full kit (can and mid pipe)
Ocho Cinco
+1!!! Don't try to shortcut it. You'll be a lot happier buying a full kit!
TurtlesScout
i was thinkin that also cuz i like the jardine and its only 100 more brand new
slip-on = can + midpipe
full kit = can + midpipe + headers
Try e-bay...there are deals on there all the time
Just get the slip on. it comes with the midpipe and you will be much happier with less work. you can put it on yourself in a snap. Good luck. I have the Jardine and love it. Bang for buck.
if your going to get the filter and the pcIII you might as well not take a shortcut on the exhaust... get at least a slip on.. i know full systems are quite expensive so thats understandable too look past.. but even a nice used slip on you could get for $200 or less and a new one for under $300
1 - 10 of 10 Posts
