I have a 05 600rr in which the valve cover gasket was leaking, replaced it and everything was cool for bout a month. Now i have another damn leak, seems to be worse after a long trip. Dripping on my lower fairing, anyone else have problems with this?
K
how many miles? What kind of oil? Did you switch from Conventional to synthetic recently?
If the seal is leaking to fix it you must start over. One of three things happened:
1.seal slipped
2.not cleaned properly before put back together
3.not torqued in correct pattern and/or range
