I hav 07 600rr just cleaned my tank fuel pump spark plug and the head of 4 cylinders. .and after clean up i just only kept 3 ltr of fuel on it..and started the bike .bike started and there's F1 lights on....is it due to?low fuel in my tank after the whole cleanup
Check code and tell us what code you get.
Eg.
Two Long Flash = 2
Three Short Flash = 3
= Code 23
No code it only remains constant after my engiene is started when it engiene is off it doesn't blink
Try to clear codes and recheck for codes
Follow under heading Clearing DTC
BOTM winner 03/15
It doesnot blink i tried a lot remains constant after i start the engiene
I don't think you need to short the plug on 07+ (could be wrong but that's what I read). Make sure bike is in neutral and kickstand is down. FI light won't flash a code otherwise.
Have a good read through this thread. It's an old sticky but there are more up to date posts relevant to your year/model.
http://www.600rr.net/vb/showthread.php?t=85319
P.S you'll probably get better answers if you post in the troubleshooting section of the forum.
