So I am in the process of building up a 2001 F4i and radiators have turned out to be in short supply/unreasonably priced so I have started looking at the rr radiators. At this point I think I have it narrowed down to the 07 08 09 model because it doesn't cross hoses across the back too much like the 05 06 from what I can tell.
So does anyone know if the 07 08 09 radiator will work with an F4i as far as dimensions, flow, temp handling, etc? I am not expecting it to be a bolt on and does not have to fit with fairings. also will probably have the fan on a manual switch just to make things easier.
Thanks for any help:
and my references were
F4i
03 04 RR
05 06 RR
07 08 09 RR
have you looked at the 03-04's yet or are they the same thing.
I just went back and looked at it and I think originally I ruled it out because of the high hose mount on the left side but I don't think that matters a whole lot so I figure that should be thrown in the mix too. Its the most similar looking rad too.
I guess now the question is: will it work?/which will work the best/easiest? :confused1
