1 - 19 of 19 Posts
600ridgerunner hangs out at wristtwisters.com a lot. I think he still comes here from time to time. I would just PM him. I am sure he would be happy to give you thr information you need. If not PM me and I will get in touch with him at wristtwisters.
Discussion Starter · #5 ·
thanks for the tip. i sent him a pm over at wristtwisters.
i don't know why i'm being so indecisive about a FE...just having a hard time figuring out what i want. and then when i find something i like, i don't know what it's called or where to get it :p
If you go to Home Depot and buy a "T" bracket and a hose clamp. Bend the bracket to the desired angle and then wrap the hose clamp around the midpipe and sandwich the bracket between the pipe and the hose clamp. Attach your plate to the bracket. You may need to drill a small hole in your plate to accomodate the brackets holes. It is one of the cleanest homemade FE's that I have seen. The best thing is that the total cost is about $4.00.
Discussion Starter · #8 ·
ok sweet. thats not the one in the original pic, but thats the same one i found on ebay. and your pic is better than the ones on ebay. i really like how that looks. i want to keep the stock signals, is that what you did there? what did you mount them to, the reflector holes?
Discussion Starter · #11 ·
ok, yeah, now that is it. cuz the triangle cutout is longer. doesn't really make a difference to me, they look the same, so i'll prolly just go with the one made for the 600rr. your bike is an '06 right? if you have any other pics from other angles of the FE, i would love to see em. thanks again man.
Discussion Starter · #13 ·
hey guys, i need some help. got my FE, trying to install it right now. i'm a little confused/having a little trouble with the 4 spacers and bolts. TheX if you could help me out, it would be great. i basically have 2 silver spacers and 2 black spacers. i don't know if i should put the flat side facing the bike or facing outside. also, not sure if i should use the black ones towards the front or back. the ways i've tried don't seem to line up really well...thanks guys!
I don't have black spacers. I used the silver spacers toward the rear. The flange is outside toward the FE on mine, gave it greater surface area to stabilize the FE itself. That setup lined it up perfectly.
Discussion Starter · #16 ·
well here's the finished pics. i wanna move my rear turn signals to the L reflector brackets, but i don't have a dremel. i don't know what to do with the wires for now, until i move the turn signals.
1 - 19 of 19 Posts
