Ok so instead of me asking the same question as has been asked hundreds of times before, i thought i would ask one i haven't been able to find an answer for. changing out the front sproket.... going up. is there anywhere that i can purchase a slightly larger front sproket, like a 17t. is there clerence issues? could you just take off the cover to clear(like with the GP shift mod). where can a 17t front be bought? i understand that a tooth on the front is equivilant to about 2.5 in the rear. so by this it would be like putting a 41 or 40 tooth in the rear.
why do i want to do this. well i want to go with a 15t up front for city/fun times. but when i take my longer trips i would like to drop the revs down a bit and maybe increase mpg a good bit. i could change out the front sproket from my 15t to a 17t in a lot less time than changing the rear sproket, which is mainly why i like the front sproket idea.
so has anyone done this? is it even possible? can you go bigger than 17t? does anyone know what to expect as far as MPG increase?
if the 17t front isn't even possible then please share your opinions on dropping teeth on the rear sproket instead.
thanks!
thanks!
