1 - 20 of 78 Posts
yeah... my FI light came on... and i cant figure out what it is... any ideas?
from the information you have given us it could be one of a million problems.
we need more to help diagnose.
any mods or maintenance recently?
does the FI light blink when you turn the key on?
have you unplugged anything recently
oh and there are about 80 why is my FI light threads that i know of already. i am going to assume that you have read those and still cant figure it out.
Discussion Starter · #4 ·
no mods... when i turn the key on, the lightflshes like normal.... turns off.... then i can hear a click under the tank while the light turns on... no flases when i put the kickstand down
Discussion Starter · #6 ·
no code flashesat least i dont think so
that is the fuel pump priming itself, and the relay cycling.
if u have a FI light on while RIDING the bike, re read my first post.
we cant help u out if u dont give us anything to work w/... (if u in fact have a FI fault code)
Discussion Starter · #8 ·
ok so i just realized something... my bike doesnt know when the kickstand is down cause the guy that had the bike before me over rode the sensor...so it wont show a fault code cause it doesnt realize the stand is down
Discussion Starter · #10 ·
yes i can have the stand down w/ engine running in 1st gear
if you separate the wires for the kickstand sensor, its the same as stand down.
here is the plug i made using the stock sensor plug.
when its in, the bike is in run mode (stand up). when i take it out, the bike is in diagnostic mode (stand down).
the connector sits under the rectifier (silver heatsink looking thing) on the left side of the bike.
Discussion Starter · #12 ·
is it bolted to the frame on the left side? next to a black one that looks exactly like it?
sorry im learning as i go...i know close to nothing about maintenance...
Discussion Starter · #14 ·
ok... so once again.... what am i supposed to be doing with it... sorry for the newb ?s again
Discussion Starter · #16 ·
no the plug is there still
Discussion Starter · #19 ·
7 flashes....
1 - 20 of 78 Posts
